NO ABS OR ESP LAMPS WORKING AT ALL WHEN TURNING IGNITION ON
Staunch
Vito 2012 w639
Hi Everyone
I could do with a pointer on a MB SPRINTER LWB 2013 with no ABS or ESP telltale lamps working on the dash at all. Ignition on both not working.
a quick scan with a verus edge scanner said front Nearside wheel speed sensor faulty and data backed this up as it was saying over 500 mph so I have replaced that. I knew that this would probably not fix the abs lamp inop problem. Verus edge functional tests on the cluster lights makes abs and esp lights work.
there is a code for an instrument cluster coding problem and a fault with the fuel tank sender unit.
is there any quick fix that somebody can point out as this is a job that is hanging about.
Has someone previously taken the bulbs out?
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
As above. Possibly the bulbs were removed as its an MOT failure if they are lit after starting the car.
Easier and cheaper for the previous owner than repairing it properly:mad:
