OM642 320CDi rail pressure too low
zedmeister
Watford, Herts.
CLK C208/2002/3.2, C Class S205/2019/220d, E class cab A124/1996/2.2
Hi
Well I'm having fun with my OM642 as well. After changing endless bits in the last year for various fault codes that have cleared up those issues (such as exhaust back pressure sensor, lambda sensor, Air mass sensor, etc) I am currently left with:
2047 Rail Pressure monitoring via volume control valve The rail pressure is too low.
The car is a CLS320CDi with Brabus D6. The indie is always suggesting with every fault that removing the Brabus kit will sort it or is the first step to diagnosis! I have changed the fuel filter but to no avail. The car has done 85k miles and drives fine with normal acceleration except when accelerating hard where it jerks and does not accelerate. If I take my foot off, its back to normal, if I keep my foot in, the engine light comes on with the above code. Any suggestions?
GAD Tuning LTD
Essex
www.gadtuning.co.uk
Mercedes AMG GTS - GLS350d
I would also recommend taking the Brabus kit off as its not the same as mapping a vehicle because you will increase the rail pressure and then increase to limiter also. But with the Brabus kits and other tuning boxes it merely retards the rail signal so having your Brabus kit on it currently will being giving false readings.
Many thanks
The GAD Team
zedmeister
zedmeister
Watford, Herts.
Update : taking the Brabus unit off fixes everything. Any suggestions?
whitenemesis
CLS55 AMG '05
Leave it off and get the car remapped properly..
zedmeister
zedmeister
Watford, Herts.
And lose 48hp? It's just a boring diesel without the Brabus unit!
GAD Tuning LTD
Essex
www.gadtuning.co.uk
Your problem is that the brabus unit is tricking the ECU and rail pressure thinking its lower than it is if this goes below the threshold you will get this error.
As we have said time and time again to members the box tricks the ecu into thinking the pressure is lower than it is, hence making the ecu compensate for the "apparent" lack of pressure.
Our honest advise would be to look in to remapping as this is the ONLY effective way of do this.
We have two of the WORLDS fastest diesel Mercedes and we did not achieve this by a tuning box.
There is so much more to tuning a diesel other than a rail pressure or Boost box.
If you need any help or advise please just ask.
Regards Team GAD
Bubble
Braintree
www.motacar.com
E350 Coupe CDI / Land-Rover Discovery 4 / Nissan Skyline 650bhp R.I.P.
I have had both my cars mapped by GAD and the only problem has been the ache from the big grin on my face :D
I have previously used tuning boxs on Mondeo diesels and they have caused problems with the check light coming on and then going into limp home mode.
