Proud owner of A150 (W169) 2006.
jonnohudski
Basingstoke
A150/2006/W169
Hi, I just bought my wife the above car and apart from a few niggles, which we knew about before we bought it, it is turning out to be a great purchase.
I have joined forums for pretty much every car I've owned in the last 10 years and find them a great way of getting advice about what could be quite costly main dealer problems.
It's got the dreaded bouncing door lock on the passenger door, and I've bought the springs hopefully to fix it, will be trying it this weekend. I'm just a little concerned about riveting the metal plate back on.
Also, the speaker grill on the same door has been crushed, so am going to try to press that out and glue it at the same time to the above.
Wish me luck on the door lock. Any little hints and tips would be greatly received.
Hello and welcome, re the speaker grill they are fitted by just the pegs going through the hole and the end of the pegs is melted over with a soldering iron.
As you will be taking the door card off it is dead easy to fit the new one and just melt the end of the pegs
ZZZZ
Welcome from a fellow 169 owner :)
I have seen a video on YouTube, with someone rectifying the bouncing lock pin with just a squirt of silicone spray. Apparently if the rubber is too stiff, it bounces too. Obviously, if the spring (or the cog) is broken, that won't help, but wouldn't hurt to try it first, I'd thought - since you can do it before removing the metal plate, just with the door card out.
jonnohudski
Basingstoke
A150/2006/W169
Thank you television. I will see if I can get the speaker grill off without damaging the lugs, as at the moment, I am unable to find a replacement part.
jonnohudski
Basingstoke
A150/2006/W169
Thank you GLK, I will pop out at lunch and buy a can of Silicone Spray.
