Cartez
My Xenon headlight lense had a crack which let moisture in. The Xenon light and side light now no longer work but full beam does. The light shorts when a new fuse is put in but full beam continues to work. I've replaced the lense and plan to pull apart the light fitting. Planning to dry out all electrical parts but wondering if anyone has had similar issues and if the short was in a specific part such as the ballast or starter and did drying out fix the issue or were replacement parts required? Any help or advice appreciate.
