ManLikeEnes
- Jan 24, 2024
- Location
- Harlow, Essex
- 2004 Mercedes-Benz C270 CDI
Greetings fellow Mercedes-Benz Owners,
I bought a lovely W203 C270 CDI a few months ago and I've had loads of happy motoring with it. However when I initially bought the car, I had to replace the boost solenoid since the present one was causing limp mode. When I ordered a new one, it arrived with a broken piece but after super gluing it with silicone sealant, it somewhat worked but I decided to order another one since it was only planned on being a temporary fix. However when I received the other solenoid, it threw the car into limp mode again and threw up codes so I ditched that one and requested a return as well as ordered ANOTHER solenoid with a vacuum filter but I was wondering if there was potentially other causes such as a vacuum leak or even a faulty MAF?
0-60mph takes about 15 seconds (when it should take about 9 secs) and I have noticed the car seems to very slightly fluctuate on idle here and there (only by about 100 revs or so) although I'm not sure if this is because of my botch job on the solenoid.
I don't suspect it could be the filters or injectors although the glow plug light does stay on for about 45-60 seconds after starting the car before going away, would appreciate feedback, thanks.
