Bradaghlad
Northern Ireland
E class 2004 320cdi
SBC brake failure
Can everyone who has had brake failure/accidents/near miss as I have due to the SBC fault please send an account of your experience to. vsb@visa.gov.uk (this is the body that decides when a vehicle must be recalled) asking them to please instruct Mercedes to recall these vehicles as a matter of urgency.
That link only opens a google window window
drmw
Yorkshire
www.autonomed.co.uk
ok - you've made your request clearly - please don't post the same request on other threads !
B
Bradaghlad
Northern Ireland
E class 2004 320cdi
Sbc pump
Pump replaced today foc by Mercedes, turns out a recall was put out for my car back in 2005/2006 . Call your Mercedes dealership and ask if there are any outstanding recalls on your car, just have your vin/chasis number ready. Good luck.
V6Matty
Newark, Nottinghamshire
i was not aware of a recall of SBC units at all, only modifications to timing and IIRC a harness for the brake wiring?
do you have the details from MB with the recall number?
B
Bradaghlad
Northern Ireland
E class 2004 320cdi
2 27/07/2005 R/2005/134 MERCEDES BENZ E CLASS AND SL CLASS brake pedal may require more effort than expected
3 27/07/2005 R/2005/056 MERCEDES BENZ E- Class, SL, CLS brake pedal may require more effort than expected 01/01/2001 31/12/2005
I found these on the vosa site
V6Matty
see link for the actual reasons for the recall in detail http://www.vosa.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=15CA6C4180C13BEA80256FEB00446996&freeText=Blank&tx= /056 is for wire chafing making it harder for the pedal to be pushed and NOT SBC failure.
http://www.vosa.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=CC59A06482E2064680257081003795D0&freeText=Blank&tx= /134 is for an inspection of the unit and testing to be conducted by MB to see if any were failing before they should, but if i read it correctly it states the brake pedal may require more effort than expected, which to me means it will depress but its harder again not the unit actually failing.
B
Bradaghlad
Northern Ireland
E class 2004 320cdi
I just called the dealership on Monday asked if there were any outstanding recalls, they said yes , two, both to do with the brakes. I booked it in for today,they would have re programmed the Sbc if it would have taken the codes but it wouldn't so they replaced it. I didn't ask them for the recall details.
Miffy
Bromley, London
CLK 320 CAB Elegance C208
All they have done, after checking the error code was the correct one is reset the counter back to zero. You will still have the fault come up at some stage in the future
V6Matty
thanks Miffy, thats what i was getting at in an odd way lol :)
Xtractorfan
S class
He did say it wouldn't take the codes so they replaced it.
B
Bradaghlad
Northern Ireland
E class 2004 320cdi
Thanks Extractorfan , they would have looked at the car on the day I called but decided to get a pump in first incase the old one wouldn't take the re program which often happens if the fault is not showing when presented to them.
