Drivenroundthebenz
- Dec 5, 2009
- Location
- Norfolk
- 1999 Mercedes SLK 230K w209 CLK 220 cdi Sport Coupe
Hi all
Just recently passenger side door closes but the window does not mate with seal all the way round. You end up with a 3mm gap between the window and the vertical seal next to the smaller window ie where the door opens.
When the door is shut you can push the window "in" by hand so it goes under the seal. I think forcing it this way could make it worse. Opening and closing the window also works but you need to be in the car. Also the window still sometimes sits on the seal rather than under it.
The wind noise is really bad - may as well have the window open!
Have tried wd40 on the seal-no real change.
Is the window out of line -need adjustment or do the seals need greasing??
Thanks for any advice.
