I will look into this in the morning
But I do have one paper on this if you would like it now
Look at the post above, I have offered it to you.
Do not worry, I have sent you an Email, just reply
And I will send you what you need
Hi Television,
Well the good news is that after reading the info you sent me I can see that the problem is caused by the window going up about 4mm too high before it stops.
Before I start stripping the door trim off to I just wondered if you had any more information on "teaching" the window lift motor where to stop. I did try putting 4mm spacer between the top of the glass and door frame and holding the lift button for 10 seconds as suggested in one of your earlier postings but sadly it didn't seem to make any difference.
I can't quite see how this would actually work because it would need a pretty sophisticated feed back system, but on the the other hand this a MB
If you do have any more info it would be much appreciated.
Many thanks
John
I will have a look, the motor has a turns counter and it usually finds it own level and this info you store with the memory buttons.
