You need a 2" long 28 torx bit to remove the air bag, do not turn on ignition without it plugged in. the wheel is held on with a 10mm hex key, and this will be tight at 90Nm
Having looked at the wheel itself there is 4 screws at the back of the wheel itself which looks like it holds the rim in place ..do I have to remove the wheel completely ,or can the rim be removed ?.The covering on the rim has split and worn with age
it has crumbled in a couple of places and split revealing the base ,I have put some black insulation tape around the top of the wheel as a temporary measure
yes it does have an airbag...but one thing I recall is when I had a new back box fitted some years back was that the car was listed as built for Hongkong market,and aquiring the box took some days
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
