You need a 2" long 28 torx bit to remove the air bag, do not turn on ignition without it plugged in. the wheel is held on with a 10mm hex key, and this will be tight at 90Nm
Having looked at the wheel itself there is 4 screws at the back of the wheel itself which looks like it holds the rim in place ..do I have to remove the wheel completely ,or can the rim be removed ?.The covering on the rim has split and worn with age
it has crumbled in a couple of places and split revealing the base ,I have put some black insulation tape around the top of the wheel as a temporary measure
yes it does have an airbag...but one thing I recall is when I had a new back box fitted some years back was that the car was listed as built for Hongkong market,and aquiring the box took some days
AMF Automotive - We are an independent Mercedes-Benz and AMG specialist located in Paddock Wood, Kent, with full Mercedes Diagnostic equipment. We offer a full
portfolio of tuning options for AMGs and can cater for all your Mercedes needs. Tel: 0203 384 4644www.amfmercedes.com/
