Chrishazle
- May 25, 2009
- Location
- Nr Ashford, Kent
- S204 2008 C220CDI Elegance Estate Auto, 2008 R171 Facelift SLK280
Acquired a set of (genuine MB) 2012 V10.0 update discs for the NTG4 Comand in my 2008 S204 C220 and have just installed the update.
From the Engineering menu I'd discovered that the installed maps were 07Q2, so system had never been updated from new. Expected to have to go back to the engineering menu to update, but..
Ejected all 6 cds from the changer, loaded the first of the 2 DVD's, system automatically detected the update disc and asked "Do you want to update? Yes or No" - autorun!! The Yes button was highlighted, so I just pushed down on the central control knob and the update started automatically. I did not have to go into the engineering menu at all.
Almost 2 hours later it asked for DVD2 - loaded that and the update continued, finishing after about 2 1/4 hours all told, "Update installed successfully, activating NAV" and the nav screen came up. Result.
I'd read elsewhere that you have to have the ignition on to keep Comand alive throughout the update, so for the first 1 1/2 hours I had the engine running, then I connected my battery charger and turned the engine off (leaving the ignition on) and turned the climate control off. Should have done this from the start, I'd have saved 3-4 litres of diesel.
I also found some good information about updating in the comand manual that came with the car - things like you can interrupt and restart the update - but once you start the update, Nav is not available until it has completed - so don't interrupt the update unless it's essential.
So - anyone interested in a set of NTG4 discs for pre-facelift W/S204 (MB part number A204 827 92 59)? PM me.
