V class heater blower replacement
matteb63
Abergavenny Wales
Cl 500s & CLS500 with LPG conversions
I have a P reg V class 230. The blower motor has packed up and Im hoping someone can tell me how to remove the dash and replace the motor please. Little Ella my 3 yr old complained about the cold all the way home last night so I have to do something...Is there a Haynes manual or something similar.
The vin number is
VSA63823423061213
Thank-you
I will run you a print off later in the day of how to do it :D
This is a crazy job to do and all of the heater out.
I wonder if it is the blower relay at fault this is the M40K 17 it sits just under the dash just below the steering wheel
Alex Crow
Super Suffolk
dash out! odd that, it is a doddle on a 638 vito, i guess the v-class has a different setup?
The heater box has to come out and all the A/C discharged and water lines taken off plus a lot more
M
matteb63
Abergavenny Wales
The blower simply became progressively worse so I,m guessing its more than the relay but I will certainly pull it and replace in the forlorn hope that it may be this simple.I will keep you posted thankyou
I will print it all out for you if you would like it,,it is rather a lot, but such is life
M
matteb63
Abergavenny Wales
sounds a little labour intensive but then I must try and repair or replace it.
Thanks Malcolm please send me the info you think I will need and thank you for your continuing help
47p2
Scotland
W638, W140, W220, W639 All gone but not forgotten
If it's the blower motor you don't need to remove the dash. The motor is located behind and under the glovebox, remove the panel beneath the glovebox for access. A simple job which will take about 40 minutes.
I can sell you a good used motor if you require
This is a sprinter,,and you do have to remove all of the dash
Alex Crow
Super Suffolk
sorry malcolm, looks like a v-class to me. as i said, it is a doddle on a vito and they are very similar.
Yes it was me miss reading ,we had a guy a couple of weeks back asking for a sprinter,,and I said sprinter in my above post,,I though it was odd when the OP here mentioned his child
M
matteb63
Abergavenny Wales
Sorry Im a little confused...Should I be accessing through the glove box or attempting to remove the dash complete?
I am printing off the instructions for you,,with an Email address i can send it to you,,you can edit it out later
I have sent it matt
M
matteb63
Abergavenny Wales
Thank you Malcolm
the diagram shows a left hand drive,are there any revisions or changes for a right hand drive?
Alex Crow
Super Suffolk
Just remove the panel above the front passengers knees, and it is staring you in the face!
Thank you Malcolm
Thats for when you are laying upside down in the cab :rolleyes::rolleyes::rolleyes:;)
M
matteb63
Abergavenny Wales
  • #19
Well I finally got round to removing the motor,switched the brushes ,now works fine... Now need to try and remove pollen filter if I can find it
Thank you for all your help.
www.ckinsurance.co.uk
