W115 clutch pedal stuck!!
brianbrian
cockney in the West Country
w124 250D, SL129-deisel
As I thougtht ,the whole clutch components will have to be replaced. This is expected when doing up a classic car, so don't get disheartened, also wheels of and check all brakes.
Tukka
Tukka
200D 1973
  • #22
Clutch problem finally sorted!! After changing both slave and master cylinders,endless hours of bleeding manually and with a pressure bleeder,reverse bleeding etc and still only getting about 50mm of resistance right at the very bottom of pedal travel,I came up with one last idea and ir worked! Though Im still not sure why. It seemed to me that the master cylinder piston was either not returning fully or not going down fully so I removed the m/c (again) and noticed that the push rod sits in a fairly deep well in the piston top.I found a suitable small metal dowel and dropped that into the hole,it came about two thirds of the way up,and then replaced the m/c and pushrod,bled the system again and bingo! I would have expected to have gained 10 or 20mm of pedal but this has restored a full pedal travel.Its been such a relief.Still not sure if the m/c I bought isnt quite the exact one or the piston is shorter?? The body of the m/c is exactly right.Anyway mystery solved and now have a driveable car.At least I can now get the car into my garage where I can start on the bodywork restoration.I seem to have gone into italics but dont know why!
