walshy66
- Jul 6, 2008
- Location
- Sunny Lancashire
- S500 W140 1998
Noticed the ABS light on and a quick inspection revealed the problem. The ABS 'reluctor' ring had split on the rear drivers side.
No easy fix I presume apart from getting the half shaft out and replacing the ring.
Just looking for some tips on how to do this and is a special press tool required?
Appears to bolt to the differential flange to flange so that looks OK to get off, but then its releasing the half shaft at the hub end with the splined drive behind the 32mm 12 point nut that's puzzling me. Any help would be appreciated. Many thanks for reading my post
