W203 bouncing door locks
NORMANWILLIAMS1
New Registration
Hi Malcolm,
I too have the problem of bouncing door lock pin on my W203 C Class Coupe, could you please send me details of how to dismantle door and fix it. Thanks.
Also I have a rear spring broken.
Do you happen to have details of how to tackle the job of replacing both rear springs.?
Many Thanks
removed email address
Door lock info sent, I can print off the spring data later, you can remove the address in edit
yelnos
Worcestershire
08 CLS 320 CDi
My passenger door lock is bouncing, too. Any chance of getting the magic papers about what to do next?
All sent and you can edit out the address
yelnos
Worcestershire
08 CLS 320 CDi
What an amazingly helpful set of instructions; all that remains is to see if I'm up to it! I don't suppose you've got equally helpful ideas about the driver's door restraint on my CLK? The mechanism inside the door seems to have disintegrated, so the door flies freely when it is opened instead of stopping in a couple of positions.
But if you do it you will miss watching the button going up and down:rolleyes:
chrisb12
New Registration
manchester
2001 c180
Hi, I've just come across this forum after also looking for a way to fix the problem with the door lock bouncing.
Is there any possibility you could please send me the instructions on how to remove the locking unit from the car?
wirralsquirral
New Registration
mercedes c220 cdi coupe
bouncing door lock
Hi Malcom,
I have just spent nearly two hours trying to excract the door lock from the door but no avail. The door lock seems to big to pass the throught the speaker hole or pass the window mech arm.
Hope you can help, many thanks in advance.
Laurence
wirralsquirral@googlemail.com
Hi Malcolm,
Many Thanks
normanwilliams1@talktalk.net
citydaz
W203 estate / 2001 / 2.2CDI
I recently suffered a similar problem with my W203 door locks bouncing - mostly in the cold. I took it to MB Tech in Warrington and they sorted it no problem. They replaced some modules and now everything is fine & dandy.
I need an Email address please
You should have it all
You should have them asmart
Hello and welcome,, all sent and you can edit out your address
clk320 Paul
Kent
CLK 2003 320
W209 same problem
Hi I have a w209 which has the same problem as mentioned above, however it's only on the nearside. Is it possible to get the dismantle and fitting instructions for the door locks with part numbers if possible.
Also I have a w203 with both sides having the bouncing door lock problems, could I have the fitting instructions for the w203 locks also.
Do you know the price of the bouncing door locks, and where the best place would be to get the new rivets to refit the door parts.
My email address is paul@thegunnings.plus.com
Thanks in advance
monkeyandminx
Galway
2002 mercedes c180
Malcolm please can you send me the details as well please.
Kind regards
Nick
