W203 C270cdi noise after turning off ignition
renrutp76
Chester
X218/2014/CLS250CDI_W211/2005/E500 Avantgarde
for a couple of months, my C270CDI made a loud noise after turning off the ignition. The noise is difficult to describe, the only thing I can say is that it lasted for a couple of seconds, and got gradually quieter. Now the noise is barely noticeable, but I have traced it to a small filter at the front of the car (behind the drivers headlamp). is thus part of the vacuum system? I may be getting paranoid but the brakes aren't particularly sharp, however the headlamp auto adjust works when the car is started.
any help would be appreciated
thejohn
London
S203 C270CDI Estate Elegance
I'm no help but mine makes the same noise and has since I brought it in Jan. I thought it was normal so i'm interested in any feedback.
renrutp76
renrutp76
Chester
Replaced waterpump and alternator pulley, noise dissapeared:lol:
Rory
Cheshire, UK
That's a bit worrying - mine makes what seems like the same noise and I also thought it was coming from the vacuum system. Was very noticeable under the bonnet the toher day - almost like a fizzing noise.
Wirral_guy
Ness, nr Chester
2004 CLK270cdi Avantgarde
If it's the same as mine, a cross between a fizz and a buzzing noise, my 270 has always done it.
Dave
johncroydon
croydon, surrey
w204 c180 amg sports plus 2013
mine makes a buzzing noise for a few seconds, like above i thought it was normal
Alex Crow
Super Suffolk
The vacuum buzzing is normal and correct, and is just the metal plate in the bottom of the modulator (or rather both modulators - EGR and turbo) buzzing as the vacuum drops.
However, in this case it seems it was the alternator pulley.
Rory
Cheshire, UK
I'm baffledhow the waterpump and alternator pulley could be noisy after the ignition is turned off - unless the OP means as the engine is coming to a stop, but that strikes me as unlikely.
Alex Crow
Super Suffolk
The OAP (overrunning alternator pulley) can make a noise after the engine has stopped, as the alternator slows down.
renrutp76 said in post #3 above that the noise complaint in this particular case stopped after replacing the water pump and alternator pulley.
If we take this as correct, it leaves few other conclusions.
Possibly when looking for one noise (maybe heard very briefly after the engine had stopped) more closely, another was found (the vacuum buzz).
We often see customers present with noise complaints, that have confused one for another - easily done.
I am sure renrutp76 still has the vacuum buzz, if not I would guess a vacuum pipe was knocked off while changing the other parts.
renrutp76
renrutp76
Chester
Thanks Alex,
The vacuum noise is still there and I am told is quite normal, however there was also a screeching noise at the same time, cured by the replacement on the idler pulley, and the water pump.
Apologies for not explaining myself very well:Oops:
Alex Crow
Super Suffolk
Thanks Alex,
The vacuum noise is still there and I am told is quite normal....
Yes, that was me last month :D
Thanks for confirming the facts and glad you have it fixed now.
