W203 Wing mirror complete removal/refit
L
Leon W
Hi this is my first post on here and hope someone can help me. I have a 2003 C220 CDi W203 pre facelift model.
Last week some $@&# :mad: hit my near side wing mirror off and smashed the casing and mirror. i managed to pick up a complete replacement on ebay :D.
I've managed to get the damaged wing mirror off and am left with the wiring loom and rubber seal left. The replacement I've picked up also has a the wiring loom included. how do I get at the exisitng wing mirror loom in the door panel or would I be better off attempting to take the loom out of the replacement and threading the old one in? if so how do I do this? :confused:
Many Thanks for any help
Leon
If you slide the cover off, you should be able to disconnect it, but if you want to change the whole thing I can send you the details of how to
L
Leon W
Im having trouble prising the clip as I have no way of holding the mirror so that would be great if you can send me the details to change it complete. Much appreciated
Leon:D
I need an Email address,, you can remove it in edit post shortly
OK you have it all, you can remove your address
Tju
Essex
S211 OM642, A209 320, W220 OM648
W203 Mirror Removal
Malcolm,
Any chance you could forward the details on removal to me as well? I have started and think I have undone something I shouldnt have:(
Thanks,
Terry.
Update; No Need now thanks, I persevered, took my time and fixed it, ;-)
Malcolm,
Thanks,
Terry.
I have been out all day and did not see the post
Tju
Essex
No Problem Malcolm, I slowly took it apart, slowly frightened myself, seeing how many bits I had it in, walked away for ten minutes or so, went back to the table, took a deep breath and put it all back together with 3 new pieces of wiring attached, and Hey Presto, it all works perfectly, even the mirror adjust which was also not working along with the indicator,
Thanks,
Terry.
plm
Malcolm,
Thanks,
Terry.
Malcolm,
can you send me the details on removel.
Malcolm,
Yes but again I need the Email address, you can edit it out shortly
tonybolding
New Registration
Cheltenham
W203 2007
I need to repair the mirror assembly
The indicator LED on the drivers side is not working with the mirror extended. Works fine when it is folded (not much use)
Seems I have a wiring problem. So I need to remove the mirror so I can repair the offending wire - I would appreciate instructions on how to remove the mirror assembly please. I have taken the cover off - now for the hard part!.
regards
mbtony@atlantiss.co.uk
OK Tony and sent, you can edit out your address
HaroldB
Pontypool
C220 cdi 2002 2.2
Hi there, afraid I'm another clot needing to remove the housing from the nearside door mirror on a C220 cdi 2002. I do have a Haynes comic but the pics do not seem to match up with my vehicle. Thanks
HaroldB
Pontypool
C220 cdi 2002 2.2
e-mail address : "w.badham@sky.com"
See how it goes with what I have sent Harold and welcome
vmuthu01
Bangalore
W203 C200 cdi/2003
Hi I have recently purchased a 2003 w203 c200 cdi and it has a broken mirror. I found a second hand mirror unit and am trying to see if I can get the steps to replace the entire unit.
Also the replacement unit I have how can we take the housing out, as it's easy to pull the mirror in the car and move the notch but on a full unit the spring is very tense and it's very hard to open the housing, is there some technique to do this
Thanks in advance
Very hard to get the cover of when the mirror is not mounted on the car.
On a 203 the door liner panel has to come off to get to the plug.
