Nathanjennings
- Mar 16, 2022
- Vito 115cdi W639
Hey guys. Had my 07 Vito for around 4 years its done 184,000 and an absolute beast still.
Although I'm having some problems with the MAF. In low gears the, especially 1st gear, the van jumps and jerks like it cant breathe properly.
Connected a OBD with live data and the MAF data was erratic, spiking and dipping uncontrollably. Also at idle its spiking to 40g/s - 60g/s which is ridicuously high.
Replaced the MAF with a cheap aftermarket one and the problem was even worse. Replaced it with a genuine part from a breakers yard and its much better but the problem is still there. When the MAF is disconnected the van runs like a dream albeit with slightly less power and obviously worse fuel economy. What's strange is the OBD tester was still showing MAF data whilst it was disconnected. Any ideas?
I've tested the wiring harness I'm getting;
Pin 1 - 5v (IAT?)
Pin 2 - 5v (Signal?)
Pin 3 - Ground
Pin 4 - 12v
Could I be super unlucky and have gotten 3 bad MAFs in a row?
Any help is greatly appreciated, It's driving me nuts!
Pin 1 - 5v (IAT?)
Pin 3 - Ground
Pin 4 - 12v
