Water Leaking In CLK Convertible
Bourbonbot
New Registration
Rainham,Kent uk
W208 1999 CLK320 convertible
Hi all,
I am also a new member, I have had my W208 CLK convertible for 4 years and love it. It has always had a drip when it rains from above the passenger seat where the window meets the roof rubber. I have had the water from the heater motor after a car wash but sorted that one.
Television,
Could you please send me the fix for the dripping above the passenger window please.
tactilis
Hampshire
CLK200K Cabriolet/2006/1.8
I think Televison has been banned from the forums.
tactilis
Hampshire
Good to hear.
Clearly I was misinformed :(
Do you still have the water leak info please (see my post 11-05-2014 above).
Many thanks if this is available.
Martin
martin [at] tactilis [.] co [.] uk
grayst
Glasgow, UK
SLK 320 V6 R170 2002; CLK 430 V8 Cab / 2001 / A208
as everyone seems to do, can i ask if its possible to have the list of CLK leaks/faults & drain holes PM'd to me? (TV/Malcom - wasn't sure how to PM you directly!, sorry)
would like to try some PM if I can regards the drain holes etc before getting into serious wet weather... cheers
Sorry I cannot do the 208, the info sheet was never updated
grayst
Glasgow, UK
any general ideas regards location of the drain holes would be much appreciated...
Its quite a good system on your car with just 5 as the drain in front of the screen.
Heater box drain is 545 and comes out somewhere under the car around the bulkhead
grayst
Glasgow, UK
not being great at reading those graphics TV, tonight I tried to trace what I thought was a drain hole down the r/h side of the engine bay next to some kinda 'aircon box' (I have pics, but don't know how to upload) I then removed the plastic inner arch covering in the N/S front wheel arch.
once I had this out I could view 2 holes which were filled by circular rubber coverings (again pics if I can upload). I removed these and cleared out a few handfuls of gunk from the whole area, mainly just what appeared to be dirt/road debris. stretching deeper into the wheel arch I pulled out a rubbery foam padding and again cleared some more dirt debris. from this tracing along the underside of the outer body sill I found 2 more 'drain holes' underneath the side jacking points, both appeared to be clear.
are these the correct (and only) drain holes I am looking for? as I will be tackling the drivers side tomorrow night for good measure.
also, as an after thought could I run a hose along these holes now to be sure everything is flowing and draining correctly giving me piece of mind??
hope that all made some kinda sense! thanks in advance...
grayst
Glasgow, UK
anyone help with this?? cheers...
mrhappivator
New Registration
CLK320, 1999, V6 3.2
Shall I send you all of the roof leak faults,, thats rear bow and side window rubbers
Hi Malcolm
Just picked up our clk320 today and it poured down with rain. Got in to check for leaks and saw a drip at the connection of the cover and the from windscreen on the drivers side (right-hand drive).
Thanks for your help sir
ricbritain
Uk
CLK 240 Convertible
2003 CLK240 convertible roof leak.
I'm not sure what model my car is (W208/209), just that it is a 2003 CLK 240 convertible. Anyway, I have a leak from on the drivers side where the window meets the rook. The seals look ok but during heavy or prolonged rain it leaks. It doesn't leak when it is sat still on the drive.
Could someone send my a copy of a trouble shooter document I read of earlier in this thread. Thanks.
richardbrotton@yahoo.co.uk
mercedes13156
West Lothian
CLK 200 Cabrio and a Ford Kuga
Hi Malcolm. Any chance you could send me that as well please? I've been having problems sealing the CLKs roof. Thanks. Willie
HarleyW72
USA
2000 CLK320 Coupe
Hello all, I have a 2000 CLK320 Coupe and I am having an issue with water in the front driver floorpan. I haven't checked the passenger side. I saw on here a few different threads before I registered and now I cant find them. A body shop told me it was most likely the sunroof drains blocked but I don't think so, I think the fresh air intake drains may be clogged (water buckets). I think I saw there is one on each side and one under the wiper. can anyone help me with this and maybe the process to remove the carpet and that thick foam that's soaked? Thanks all :)
Brendan Fitzpatrick
Clk A209 55AMG 2004/ E250 CDI 2013
Hi I’ve had my A209 for about 5 years. Now every time it rains I’m getting disco dash. Any ideas??
www.W140.co.uk&www.r129.co
