2003 W220 SRS fault Drivers Airbag code 9103
G
Grob115
I have a problem with my car fault code 9103 resistance to high at drivers airbag squib.
Its not the clock spring as that has being replaced.
Have read there are repair looms for other models but have not seen one for the W220. Are they generic?
Anyone else have this problem?
Regards
Any seat item could fail, it is often the connectors and cleaning them with a good non drying switch cleaner solves the problem, the fault will need code reader to clear it once fixed.
G
Grob115
Fault is
DTC 9103 – the resistance value in the ignition circuit containing component R12/13 is too high drivers airbag
no codes relating to any other airbag
Fault is
If the seat connector plugs are making a poor contact then the resistance will be too high.
G
Grob115
Problem sorted. Cleaned connectors at airbag control unit, clock spring and block connector at steering column. Reset code using icarsoft i980.
Seems ok but my guess it may need the harness repair at steering column plug.
