help e300td low power
AMC
Hi i,m in need of some assistance i have an 1998 e300td w210 automatic and it seems to have an intermitting fault of the turbo not working, ususally car is fine accelerating upto 60 mph then turbo seems to stop working and car is very flat and does not change up gears at all until you release throttle.
I have changed the vac boost valve and thought of changing the air flow mass meter next but this can be a costly excercise if still does not cure the problem so i would be greatfull if any advice out there many thanks.
Try the car with the MAF unplugged,it sometimes proves the point
