Latest update re my C220 Majestic Beauty!!!!
Hydraulic lock of the engine I believe - cylinders full of water
Hmmm. I was going to say, on the video, the compression sounds a bit low....
These can sound like that, especially when laid up for a while, as lifters bleed down etc, but given its history there could be damage.
At last. Video has uploaded:-
Second video sounds a bit better.
You need to empty the tank, that is water and diesel being mixed together. Did the hydro lock come from driving into water?
Once the tank is empty, get some fresh diesel in it. New fuel filter and make sure you have clean diesel at the filter.
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
I noticed your charger is set on a 'start' setting, what voltage is that outputting? anything greater than a charging voltage while your battery is connected to your car of c14.5v will not be doing your electronics any good at all!
NBurns
NBurns
Sunny Hampshire by the sea
www.facebook.com
A180 CDI AVANTGARDE SE CVT,169.007, 2009
  • #45
That Was a brand new fuel filter!!! Are you telling me to replace that again then?
NBurns
NBurns
www.facebook.com
  • #46
Okay. What i was doing was using the charger to give it a boost while attempting to start. From now on I will stop doing that then and just use the girlfriends charger to keep the battery charged up between testing it.
NBurns
NBurns
www.facebook.com
  • #47
Nope. The hydro lock was a combination of the car not being used since November last year plus rain water getting in via the injector holes. Once I realised this I then bought a cheap gazebo to keep the engine bay dryer.
Have I seriously screwed up a brand new fuel filter?!!
Tony Dyson
God's Country
You can use boost, start and repair settings on battery chargers as long as you disconnect the negative post from the battery to the car chassis these settings can output anywhere between 16-18v.
It does seem to be on a high setting.
Well, diesel doesn't look like milk, so you need to find the source of the horrible fuel. You need a sample from the tank.
If that's what's going into your filter, then yes it needs to be replaced.
John Laidlaw
Wirral
Land Rover Discovery 4
I was also wondering the source of the fuel and the water contamination , that’s not even dissolved by the look of it
umblecumbuz
Wales and Gozo
The diesel shown is from the low pressure side of the system, before it's got a far as the high pressure pump, so this is basically diesel and water mixed by age and the action of the lift pump.
You can get away with re-using your new fuel filter (not ideal, but as it's new and you are watching the pennies, it is possible), by flushing fresh diesel through it.
Your next step - as Blobcat - is to drain the tank and refill with a generous quantity of fresh fuel, not just 5 litres .
Then you need to flush through the high pressure side as well. You can do this by cracking open an injector feed pipe once you have made sure that good diesel is entering the high pressure pump.
Then - wonder of wonders - your engine will fire up and run sweet as a nut!
Probably from the pump hoses, they can leak badly :rolleyes::D:p
The filter medium won't deal with water and will break apart internally. I wouldn't chose to reuse if I had a choice.
You may as well flush the hp side by spraying the contaminated stuff through the injectors,some of it will end up in the tank via leak off anyway.
Opening the hp side to bleed is not ideal on CR and generally causes more problems than it solves.
umblecumbuz
Wales and Gozo
Interesting, that.
Forgive me, but I thought that - as diesel can absorb water in storage - separating out any water in the diesel was part of the purpose of the fuel filter.
John Laidlaw
Wirral
Interesting, that.
Just particulates /solids I believe ...
Interesting, that.
A small (less than 1%) amount of water will seperate out in the filter and will drop out of suspension in a filter designed with a water seperator, and will sit at the bottom of the filter.
With this amount of water, which seems to be visually the same as when a friend of mine swapped the coolant supply and diesel return lines on a VW golf.(that was fun) It seems to be emulsified as others have mentioned.
umblecumbuz
Wales and Gozo
Think you'll find they're designed to separate out both impurities and water.
So - being non-technical - I'm presuming that the filter innards are built to cope with water without 'breaking apart internally'.
On my old boat with a diesel filter, I've removed more than half the contents before now, which have been dirty water. Maybe canister filters are made with different materials that break up more easily?
