Maitrebruce
- Sep 1, 2021
- S600 W140
Hello,
So I have a Mercedes S600 W140 coupe from 1995, which has been stationary for a while because of a rather painful problem, therefore ASR problem, after several diagnostics I decide to replace the two butterfly boxes (Driver and Passenger), I now have new fault codes and still the ASR light, (no acceleration ......)
The fault codes are as follows:
002 : Coolant temperature sensor 2 B11/10
003 : Coolant temperature sensor 1 B11/10
004 : Air mass sensor with hot wire B2/4 Volt too large / small
016 : EGR switchover valve Y27/2
022 : Oxygen sensor heater G3/4
024 : Oxygen sensor heater G3/4
028 : LH resistance trimming plus R17 / 3
What do you think ? Thank you for your opinions
Regards
Regards
