Mercedes S600 W140 ( Problem ASR )
Maitrebruce
S600 W140
Hello,
So I have a Mercedes S600 W140 coupe from 1995, which has been stationary for a while because of a rather painful problem, therefore ASR problem, after several diagnostics I decide to replace the two butterfly boxes (Driver and Passenger), I now have new fault codes and still the ASR light, (no acceleration ......)
The fault codes are as follows:
002 : Coolant temperature sensor 2 B11/10
003 : Coolant temperature sensor 1 B11/10
004 : Air mass sensor with hot wire B2/4 Volt too large / small
016 : EGR switchover valve Y27/2
022 : Oxygen sensor heater G3/4
024 : Oxygen sensor heater G3/4
028 : LH resistance trimming plus R17 / 3
What do you think ? Thank you for your opinions
Regards
The fault codes themselves, as you have posted, are they not
indicative of your problems.
Welcome to the forum.
Maitrebruce
S600 W140
hello thank you for the welcome
After error reset there are only two errors left:
016: EGR switchover valve Y27 / 2
028: LH resistance trimming plus R17 / 3
The question is, can the EGR part affect the ASR? And what can resistance triming correspond to?
What do you think ?
Thank you
Personally no idea, job for a merc indy or someone else on the forum will hopefully hover in soon.
Where are you based, someone may know a good garage for you
