S210 interior bulb replacement
adrianb
Nr Saffron Walden
W210 E320cdi Est. W124 E220Est, W124 230TE, W123 230TE (various) W123 200T.
Took the plunge back into Mercedes ownership a few months ago (just can't keep away..) and am gradually working through the fixes on a 2002 S210 Avantgarde estate (well Alex Crow is mostly).
One little problem that should be simple enough for me to fix is the light fitting underneath the glovebox that illuminates the front passenger footwell.
Mine is now duff (probably- not certain what should activate it), but I understand that only the whole unit can be replaced, not just the LED bulb, and I don't fancy just chucking £30 or 40 at Mercedes.
As it was easy to do, I removed the unit (it pulls out easily) and managed to dismantle it - see attached pics (hopefully) below - without breaking anything, so it reassembles.
Does anyone know of an led that might fit, even maybe with a bit of bodging/soldering?
Regs,
Adrian
Lexman8
Yorkshire, The French Alps & Quahog
CL500 (2001): Distronic, Bose, Keyless Go; Honda CR-V EX (2011)
My footwell lights come on with the exterior lights. The original ones were so dim that for a while I didn't even know I had them.
My first attempt to improve them was to buy some 12v yellow LEDs, drill holes in the plastic to hold them and solder them to the existing pins once the small circuit board was pulled off. See first pic. These still weren't bright enough so I then bought LED panels similar to this one: (can't find the actual ones I used)
http://www.ebay.co.uk/itm/2x-COB-T1...439?pt=LH_DefaultDomain_3&hash=item51c95e1a07
They fitted neatly in the existing holders into which I also fitted a piece of yellow film to get the correct colour to match the other ambient lighting. Again I just soldered the connections. Second pic shows them in action. I subsequently decided they were too bright(!) so an easy fix was to cover half the holder in black plastic tape. I'm happy with them now. :)
btw, they aren't monitored so no worries about 'CANBUS' compatibility (well, at least on my car).
_
A
adrianb
Nr Saffron Walden
Thanks Lexman, a very neat job and good result.
