slk indicators
That sounds very kind Malcolm - only problem is that neither Val nor I would have the beginnings of a clue how to find or recognise the ECU, and the thought of disconnecting it and removing it (let alone replacing it afterwards) fills us with total terror. Perhaps our sign-in should be "dumbunnies" not "Dan&Val".
If you could source the part so I could buy it from you, or if you could advise how/where to source it, should my local MB specialist be able to do the job? So far their response (which I'm sure you have heard before) is "no problem squire, just give us £600-odd + VAT + labour and we wil replace the whole ECU". They've said it is unique to the vehicle by VIN no. and can't be interfered with, but that does not seem to be altogether accurate does it, at least so far as the flashers controller bit goes?
Or is there ANYTHING we could arrange whereby you could do the repair on the vehicle? I am absolutely staggered at the volume of problems you have solved on so many different MB models, helping people so readily on the Forum, so I must of course respect your wishes. Please feel free to email me direct if you prefer.
Best regards Dan
Best regards Dan
