W124 central locking issue - electrical drain
verysideways
Berkshire
www.petrolheadnirvana.com
S124 E36 AMG
Wonder if you guys (and girls?) might be able to help with this.
My car has an electrical drain which will flatten the battery in about a week. Having gone through the fuse box with care, the only two circuits with any draw when "all off" are the clock and the central locking circuit.
Now funnily enough the central locking circuit doesn't work that well:
1. If i lock or unlock the car using the key in the passenger door, all the locks work as expected (so i think the vacuum pump is working correctly).
2. If i open each door individually the interior lights come on and go off as expected (so i think the door switches are functioning correctly).
3. If i lock the car i can unlock it with the IR remote, but...
4. I can't LOCK the car with the IR remote.
So - does anyone have any suggestions as to how i might trace this?
I could do with a wiring diagram for the central locking for a start huh?
And where is the central locking vacuum pump?
Any tips gratefully received.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
On a W124 estate the pump, comfort module & RCL locking brain are under the o/s/r seat
The RCL brain is coded to the keys. On most cars (those with DAS excepted) nothing else is coded to the car so can be swopped
Nick Froome
www.w124.co.uk
The German Flower Pot
Cambs
www.turbo-babes.co.uk
must say both of my w124's are terrible battery wise
i charged both for 30 hours with a mains trickle charger and left them and after about 8 days both were dead
changed batteries on GFP 2 about 3 times in 5 years and its always been the same and now ive got 2 they both do it
1 has an all singing and dancing alarm and the other has nothing yet they are both bad
So simple these days,, a clamp meter can be bought for £30, and you know instantly if it is the battery or the car
Andy Cottrell
E300D 1994 Diesel
My W124 Estate pulls 20mA from the battery when left parked and locked. Alarm not on. I haven't investigated which circuit(s) pull the current, I've just accepted that after a few weeks without use I need to charge the battery before attempting to start it.
biglips
Bristol
S211 E500
I have an update on the original post, having recently bought this car.
The central locking symptoms are unchanged (ie cannot lock the car with the remote, but unlocks remotely OK and central locking works fine if engaged manually with key)
BUT if I put the key in the boot lock and lock the boot manually, then press the remote button with key still in place, the red light flashes and the central locking engages perfectly!
I dont understand :confused: can anyone throw some light on this??? Any help much appreciated
What is the car please
grober
Scotland
W204 C200cdi estate
There should be an IR receiver on the rear panel below the boot. It may simply be a weak signal from the remote. Sticking the key in the lock may get the signal to the control unit more effectively.
grober
Scotland
W204 C200cdi estate
Common fault is the boot interior light staying on due to faulty switch.
biglips
Bristol
S211 E500
Thanks Grober. Unfortunately I do t think this is the problem as all 3 keys have the same problem and the range for unlocking using the remote is very good! I will check the rear boot light although the battery drain has not been a problem for me since I have owned the car.
Tom
