Wheel bolts too long? Alloys on a W209
Thanks Malcolm, some of the bolts will have the extra thread due to the orientation of the bolt in the vice as I completed my hand made cuts. I'm guessing it's the clamping force between head of the bolt/wheel/hub that makes for a tight fit rather than anything else, and any more threads that stick out the back of the hub/drive flange are superfluous?
Yes, the bolts I eventually needed were taper, as the wheels I have are MB 15 hole copies, this has given me all sorts of problems obtaining the correct bolts to complete the job.
Yes a sure thing,,it does depend on the where the saw goes into the thread.
Pleased that it all worked out OK
Top Cat
Milton Keynes
(97) W202 C230 Elegance Estate
I thank you for all your comments, help and guidance with this too - you are a very patient man!
Thank you:D:D
Its easy for me as I am so old,,back in the 50's everything was DIY or go without, and wheels falling off back then was common place :(
It is always a great pleasure in being able to pass any information on these things, cars are not very DIY orientated these days so not many get the chance to learn
