Sam Stoddard
Hey guys I’ve been having issue with my boot soft close and also the central locking not working. On my 2003 SL350 (R230)
In another thread I went through everything I’ve done so far including sealing every single possible leak from the PSE to the boot actuator.
I’ve also stripped down the pump and can’t see anything wrong inside.
The PSE operates everything in the car correctly other than the soft close (it doesn’t cut out even when both micro switches in the boot actuator are sensing it closed.
However after three times of the soft close working okay it stops and takes the central locking with it.
I then disconnected the hose for the “HECK” port and blocked it up in the pump to fully check that it’s not further down the system. I activated the boot soft close with this hole blocked up and the pump still ran for 10secs +.
Is this a software issue that can be fixed OR is it a broken pressure sensor in the “HECK” part of the PSE?
What could I do to fix as I can’t afford a new PSE right now, especially if everything else on the pump functions correctly!
please hellllppp
please hellllppp
