NBurns
- Jun 16, 2019
- Location
- Sunny Hampshire by the sea
- Website
- www.facebook.com
- A180 CDI AVANTGARDE SE CVT,169.007, 2009
- Thread Starter
- Thread starter
- #81
Engine sounds low on compression still.
Your injector seals are also leaking unfortunately, I can definitely see number 1 puffing away, not sure on the rest, if they are all leaking badly, it will never start....
That’s probably because we decided to use the old bolts. Just to get her started up. Once she was running again we were then going to use the brand new bolts and torque them properly. Ie the 7Nm plus 90 degrees way.
I am also concerned now that I have buggered up my injectors with white stuff. I hope not at this stage because I could only afford the end nozzles for now and even getting those out was not easy.
If I could find my new torque wrench I could then tighten them down properly.
