Mercedes-Me Adapter
MacoE250
Durham
2014 E250
So It's pretty much a waste of time. It's only really any good when your cars parked on your drive. Not sure which cars allow you to turn the heating on inside the car but if you've got to be within 10m then that's pointless as well.
Who would even bother doing it when your that close to been in your car.
As for the door locking system, if someone's trying to open the doors on your car and your 10m's away your proberly going to know about it anyway.
JBell
Torquey
C350 CDi Estate (GAD Edition)
It does a little more that that
MacoE250
Durham
2014 E250
Like what?
Telling me the Fuel level, again pointless. You need to be in your car to refuel.
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #85
Mine has arrived the wife has just informed me.
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #86
Part no. If you wish to order
Includes a small bit of Velcro to stop the OBDII port cover rattling against it.
Craiglxviii
Cambs UK
That looks great Q!!!
............What does it actually do?
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #88
It really is plug and play. I've blanked off the Adapter ID and VIN.
Plug in, connect to the adapter in the Bluetooth settings on your phone, open up the App and select add new vehicle. Turn engine on when prompted. It does the rest itself. Top tip - turn COMAND off whilst you do it as mine wouldn't configure the vehicle until I did. Must be due to also connecting via Bluetooth.
Once up and running. As I'm on a .5 of a mile it's rounded it to 76467 miles.
When you switch off it tells you voltage and how long since last run
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #89
I can pick it up in my office too which is about 50m from the vehicle.
MacoE250
Durham
2014 E250
Looks like a good piece of kit carl, what features do you actually get then?
Can it park your car, unlock the doors, turn on your heating? Or is that just cars with it factory fitted?
Vehementi
Essex
C250 AMG Sport Edition Coupe (C204), 2011, 2.2 CDI
I've been tempted by this, but I'm not sure if it's worth popping in.
Carl, could you do a review of it once you've had a tinker and a play with it please? :)
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #92
You only get those features if you have a modern car with it factory fitted. You need built in wifi for that I'm led to believe.
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #93
Will do.
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #94
Some screenshots from the App.
Still telling me about the vehicle.
Location vehicle parked when engine switched off.
Route vehicle took whilst driving. Although I was stationary the equipment on camp can play havoc with GPS signals. Detail here is dependent on what you set it for in the settings.
Preferred service partner
Battery info.
Emergency calls
Book a service
Set reminders for maintenance.
Refuelling reminder in settings. The app will record any fill ups you do, location, amount put in and cost if you have the price in the app.
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #96
I'm sure I can live with £5.02p
MacoE250
Durham
2014 E250
What's your thoughts then carl? Is it useful or just a novelty that you will proberly never use?
First thoughts from what I've seen is that it would be a novelty for me.
Personally I wouldn't use the app to check how much fuel was in the car, again with the mileage unless im checking it to tell my dealer for a valuation or to work out what service is needed I don't even check it.
The reminder about parking time isn't bad, but I'd more than likely forget to put my details in to ever use it.
JBell
Torquey
So I just spoke to Exeter MB and they want me to go in with ID etc to register it all
C350Carl
C350Carl
Middle East
BMW 740Ld xDrive
  • #99
To be honest most of it is a novelty. But I will get some use out of it. More because I've paid £45 for the adapter! Lol
I like the function of being able to check the cars location it was parked, useful if visiting new places, and ready access to battery and fuel levels. Assuming you're close enough to the car.
Would be better if the Adapter had a data connection to give you live info anywhere. But that would have made it prohibitively expensive so can understand why it doesn't.
MacoE250
Durham
2014 E250
I suppose for £45 it's not the end of the world if it becomes something you only used every now & then. Teesside have one adaptor left & are keeping it for me.
It would of been a great piece of kit If it had been able to open & lock the doors, even if the lights flashing function worked so you know where the car is. Them features would of been good.
