Edward_brabus
- May 14, 2019
- S320 CDI
hi guys, im struggling with my car. I got some crazy problems with my mercedes. Please if any one can help!
I turned my car on and comes up with an esp/ abs fault. I put into D and tried to drive but it was as if it was dieing hardly moving, tried to put it into P but it did not go into P only neutral and drive. Doesn't allow me to put it into reverse or park. I turned the car off and waited after 5mins tried again same problem. The car was in neutral so i pushed the car back few metres and then started it and car was ok i was about 80 miles away from home and got home with no problem. Once i reached home i turned it off and started it to see if i get the abs and esp fault again and it came back on and again did not go back into p.
I left the car till morning same thing in the morning.
I sat in the car and the keys were in the ignition but car was off, randomly the speed went to 160mph and mileage was going up, on the sat nav it was showing I'm moving but the engine was not even on!
I been to mercedes specialist and been told its the conductor plate which i have replaced yet the issues remain the same, now i been told its the esp control unit which is very expensive and im not sure if this is the problem
When this fault does not come on, the car drives perfect gears change properly with no problem, even in manual or sport mode its fine and it drives good unless i turn the car off and the fault comes on.
Can any one advise me or had a similar problem?
I have uploaded two images showing the abs/esp fault and the 160mph fault
