The saga is almost over - 2005, C220 CDI Classic SE, S203.208 (Estate), OM646.963 Engine
The grey tube will go to a vacuum source. In a petrol car this would be the inlet manifold. On a diesel I would guess it has a feed from the vacuum pump.
umblecumbuz
Wales and Gozo
... and in the twist-to-remove plastic housing there is a diaphragm, nothing else. It is remotely possible that one of the diaphragms has a leak, but not both at the same time. Test the gearing mechanism to make sure it's free to move. Don't look for large movements, it only moves about a quarter inch max. If it's stiff you can lubricate it, but usually the system gives no trouble.
And don't confuse this with headlamp beam adjustment. This is done by a plastic screw, visible from above, on each headlight.
NBurns
NBurns
Sunny Hampshire by the sea
www.facebook.com
A180 CDI AVANTGARDE SE CVT,169.007, 2009
  • #84
Okay. Where will that vacuum pump be? Close to the inlet manifold?
NBurns
NBurns
www.facebook.com
  • #85
Yes. I attempted to move the gearing inside and it would not budge. I did wonder if I could lubricate it. Both were very stiff. And yes I have already located the black plastic screw. I do need to move that for the other failure. But first I need to do when it's a bit darker and in front of something where I can current positions of lights.
I have just got back home now and need to eat.
NBurns
NBurns
www.facebook.com
  • #86
At least there is no mention of an emissions failure on the list given the black death / fuel contamination / injector rebuild issues....
Yes. I was shocked by that. Which means that all my cleaning efforts worked. Even though Halfords's complained that my exhaust was smoking too much and they reckoned it was burning too much fuel. Is that possible?
davidsl500
As its a diesel the engine wont produce a vacuum on the inlet so diesels have vacuum pumps which can be electric or belt driven. Yours will be belt driven from the crank. You can probably find it by looking at your brake servo and following the vacuum hose back to it. The pump may feed a little manifold with multiple pipes coming from it.
It's driven from of the cams on the front of the engine, but otherwise spot on :)
NBurns
NBurns
www.facebook.com
  • #89
One of the cams? So I am looking for a pump roughly where the lower crank pulley is at the front of the engine , correct?
NBurns
NBurns
www.facebook.com
  • #90
I thought I would show what Halfords (forget what people call them now?!!) were going to charge me for this lot.
No sorry, stupid phone keyboard !
Yes one of the cams. End of the camshaft. Drivers side camshaft on the front top of the engine.
NBurns
NBurns
www.facebook.com
  • #92
Okay. Will have a look when I get back to the car again. Thank you.
Why were they charging more for one wheel bearing than the other given they are the same part and same job?
And why change when they can be adjusted?
I wouldn’t be surprised if there’s nothing wrong with them and they don’t require adjustment even. Mercedes do appear to have a bit more movement than others when set correctly. Depends if they’re looking for work on a £10 MOT...
Call me a cynic but I wouldn't be at all surprised...
umblecumbuz
Wales and Gozo
To locate the vacuum pump, just look as directed above (front and left, on end of cylinder head). It's the object with a vacuum pipe coming from it. You can check its operation with a vacuum gauge, but if the brakes work fine - which they obviously do as they have just passed an Mot - the pump is not at fault.
If necessary, it is possible to overhaul this pump and fit new O-rings, but I reckon you've taken enough of this motor to bits already, and I wouldn't recommend it!
As far as the wheel bearings are concerned, there was no mention on the Mot of noise, which would indicate worn bearings, so these are probably fine and just need simple adjustment as already described. Don't let Halfrauds take you for a sucker - you know enough about your motor by now to do this easy adjustment yourself.
NBurns
NBurns
www.facebook.com
  • #97
Well exactly!! I don't trust them at all.
NBurns
NBurns
www.facebook.com
  • #98
Yep. I even laughed at the tyre price. All mine are just 10% worn part worn Pirelli's which I can get fitted for £35. And i am very happy with them. So, I will get another one of the same.
NBurns
NBurns
www.facebook.com
  • #99
When I got back to Jane's house we had a discussion about it. And my first thought was that matey boy in Halfords had just grabbed hold of the tyre and wobbled it. There was absolutely no measurement done at all. And I was then annoyed that there isn't any measuring tool for this. Because there needs to be.
Garages are still ripping people off and making money on stuff that really does not need doing. It's criminal!!!
NBurns
NBurns
www.facebook.com
  • #100
That was the word i was looking for 'Halfrauds', love it!!!!
And yes you are right on all counts. Currently at home in Gosport getting my WIS up and running so as to check these things.
And I agree with you on my knowledge now. And growing more all the time.
